Saltar al contenido principal
El Samsung Galaxy J2 es un teléfono inteligente Android que se lanzó en noviembre de 2016.
Preguntas 99 Ver todo
My phone is not turning on.
my phone's battery was down while i was talking through it. suddenly phone switched off . i connected this to charger but it was showing nothing on phone screen. till now it's not charging , not turning on too.please suggest what to do now.
Es esta una buena pregunta?
Puntuación 31
25 comentarios
j2 switch off on problem succesfully
- de
Hi I have the same problem with my Samsung Galaxy young 2 I tried to press volume, home and power button but it's still not working is just turning off and turning on
Please help
- de
My phone is samsung j2 pro now my phone battery is full just i switch off the phone than see battery is low plz give me a help
- de
G318H is not turn on or turn off.
Please please help
- de
my j2, I actually had reset my phone and then rebooted it since it is the only way that I saw that can power in my phone because there are these like choices saying if I want to reboot it or have reset or have it updated and chose reboot. now it's like 30 minutes and my phone keeps only on vibrating and displaying the Samsung word on it
- de
Mostrar 20 comentarios más
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks. I have fixed it! I pressed volume, home and power button together. It is working now. Thanks again !!
Fue útil esta respuesta?
Puntuación 18
24 comentarios:
sir it is a battery problem if u change the battery then it will be fixed
- de
volume means? + or -
- de
Betary ok but no trun
- de
I try this but no on
- de
I also have a problem my Samsung galaxy j2 does not want to install anything how can this be fixed
- de
Mostrar 19 comentarios más
Do you charge the phone for around an hour. If no, try it and see how.
If yes, try to press volume up, home button, power at the same time. This works for my s7 edge that have the same issue with you. If nothing comes on, try to press volume up and power at the same time.
Also try to replace your battery, a dead battery may cause phone not to boot.
Still no response? Maybe your logic board maybe dead. If yes, return your device ASAP before the warranty is void.
Warranty void already? You should run out of luck, you can't fix it anymore. Because normal users can't do it
Puntuación 8
2 comentarios:
Now i what to do
- de
same problem there ....my phon should not open when power on screen has been blinking black light
- de
Añadir tu respuesta
Udita Mandal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 24
Ultimos 30 días: 124
Todo El Tiempo: 78,830
