Why doesn't my DVD player turn on?
Whenever I press the power button on my DVD player, it doesn't turn on, and nothing happens on the screen. What should I do?
Es esta una buena pregunta?
Ensure that your power supply cord is plugged in. If you are using an extension cord, ensure that the extension cord is plugged in securely. If you are using a power strip, make sure that it is plugged in and that it is switched on. If the problem persists you might need to replace your power cable.
Fue útil esta respuesta?
You might instinctively attempt to power the unit on only using the remote control, so be sure the remote control has fresh batteries.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 295
