How do I turn safe mode off?
Safe mode came on and now I have no volume and I can't power down my tablet.
Es esta una buena pregunta?
The last I heard you put a pin in where earphone goes and hold it
Fue útil esta respuesta?
This is the second time I had the problem all right it's very simple turn off your tablet then take something sharp like an earphone or something sharp the end where it would go in in the little hole at the top where you would put the earphone what you do is you put it in you leave it there on the counter 20 pick it up push it back in at the counter 20 as you're turning it turning it on it should be fine
Beside headphone plug and n there is a reset hole u put a pin in and hold down for a few seconds. This should correct the problem.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 842
I don't have this problem it just says safe mode in the corner
- de Midnight Wolf
