Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
iPhone 6 WiFi/Bluetooth Not Working
So for the past 6 months or so, my GPS has never worked accurately on my iPhone 6. It would get close to my location, but would always lag behind a bit. I never worried about it because if I'm travelling I usually get my wife to use hers.
BUT, now I've found a need for accurate GPS on a daily basis... So I purchased a new antenna and replaced it.
The new antenna worked (properly - was recognizing WiFi, had bluetooth capability, GPS worked, everything) for about 20 minutes, and now the option to turn on WiFi/Bluetooth/GPS is completely disabled.
Like. If I go to Settings > WiFi, the button is just grey. If I go to Settings > Bluetooth, all I get is the circular loading symbol and it won't stop "loading."
So... I talked to someone and he recommended restoring my phone to factory settings. I done so. I erased all content/settings and set it up as a new iPhone. The problem persists. I can not connect to WiFi, I cannot use bluetooth, GPS does not work.
Any help would be much appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 8
Agregar un comentario
1 Respuesta
بعد ضبط الإعدادات ومازالت المشكلة تأكد من القطع وأي فأي داخل الجهاز عادة تحتاج الى استبداله
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
tylert4444 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 3,156
