Should I replace Motherboard?
Hi all,
My camera is not charging or responding to anything, either plugged in into a wall charger or laptop ect.
Background:
I believe I damaged the motherboard by charging it with a crap usb charger (output of 5.35V). It smells a bit like burnt electronics and it heats up if I connect it to the power. Even with no battery, the camera does not respond. I have tried other batteries so that is not the issue. I have tried other cables and is not the issue either.
The camera is out or warranty and GoPro support wont even try to look at it :(
The Question:
I believe that the charging circuit/voltage regulator is part of the Motherboard. However, I am afraid that this would not solve my problem (ie. may have damaged other parts of the camera). I am an Electronics Engineer and I am able to replace the board.
Just wondering if someone has done it before or had similar issues??? I do not have a schematic to diagnose the fault so it is a risk if I decide to replace the motherboard and it does not work....
Thanks for taking the time to read this
Cheers
Es esta una buena pregunta?
