Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
iPhone won't turn on after I dropped it
Iphone won't working or turn on after i dropped it
and when i plugged it in the charger it doesn't show anything
and there is nothing on the screen
is the problem with the battery or what ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios:
Batteries don't easily go bad like that. Does the phone heat up in specific spots and/or does it heat up a lot in a specific spot?
Sounds like a power management ic chip has gone bad from the shock taken from dropping the phone. How far did you drop it and if you know which part of the phone did it hit on first and what surface?
- de
there isn't any scratch on the phone !! just some small scraatch on the screen protecter but when i remove it there isn't nothing on the phone screen
- de
Agregar un comentario
4 Respuestas
Dear Mareshall Teach,
Do you hear the charging sound when plugged in?
If thats the case you could just repace the screen, or reconnect the lcd cables and try again .
Fue útil esta respuesta?
Puntuación 0
6 comentarios:
no i didn't hear anything
- de
Like what Ben suggested, it might be had taken a pretty bad shock on the chip and you try could Hard Reset by holding both the Power/Top button and Home Button for about 15 seconds until iPhone turns on, if it still doesn't work, I would recommend you to visit the apple genius bar if you still had warranty.
- de
are u sure the the problem isn't with the battery ?
- de
The battery going bad is very highly unlikely. If you want you can replace the battery follow the instructions below:
Guide:
Reemplazo de la batería del iPhone 5s
Battery Part:
iPhone 5s Battery
Adhesive Strip for battery:
iPhone 5s/5c/SE (1st Gen) Battery Adhesive Strips
- de
I dropped my phone hard on the stadium cracked phone but it had a colorful glitch and I couldn’t see my phone my dad replaced the screen but the phone shows no sign of life ? Like it won’t turn on or anything ?
- de
Mostrar 1 comentario más
I have the same problem my phone wont charging or turning on after I dropped it
None of the buttons work even the switch and the sound when i plug the phone
My iPhone 5s dont show anything and any solution on YouTube dont work
It have a small hole just under the flash light and heat up at the same place
Photo of the phone:https://image.noelshack.com/fichiers/201...
Please help me
Puntuación 0
1 comentario:
I guess it could be the Power IC Chip that went bad.
- de
I really think that it is the Power IC because it supplys the Power to all of your components and it is very easy to damage when you drop it.
Puntuación 0
HI my name is abbass kasalany and my iphone 5s suddenly turn on and off and stop didnot charge and nothing on the screen I ve change the screen and nothing happened what the of proplem for iphone plzz give me an answer fast plzz this is my GMAIL GONDABADAO@GMAIL.COM PLZ HELP
Puntuación 0
Añadir tu respuesta
Mareshall Teach estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 10,095
