Dropped by mistake phone in toilett.
Hi...
As stated, my S6 Edge has taken a bath in the toilett.
The phone was not starting for 1 day.
Now the phone is starting only then battery charger is connected.
The phone say that the battery is 100 % charged.
Then I disconnect the charger then running, it just dies.
Sometimes when I try to boot I have to do Volume Down + Hometab + On buttom and then choose cansel then screen boots up. Then the phone boot up.
I have done a faktory reset.
I wonder, which parts is most likely to be changed?
Regards
A clumsy person :(
Update (07/10/2016)
Hi again...
I have now cleaned the phone inside and changed battery and charger port.
Problem still exist.
Any other solution I might try?
/NBonline
Update (07/16/2016)
Hi again...
Tested with disconnecting the battery from motherboard for 6 hours .
When i connected it again I could start the phone without charger and it show probably the right battery status.
After abaout 6 hour the phone went dead again. It worked perfeclty until then.
Time to test it again and see if it get any better.
/NBonline
Es esta una buena pregunta?
4 comentarios
Thanks for quick responce!
I will take it appart and clean as you advised.
Do you think anything else appart from battery should be replaced?
/NBonline
- de Niclas Brorsson
Not until you know what you have after you clean it and replace the battery. That is truly only the beginning of the trouble shooting. It give you a clean starting point.
- de oldturkey03
Ok, thanks again for fast answer. I will do a cleaning and replace battery, then will se what happens.
Hi again...
/NBonline
