Can u put 5s in a 5c case
Ca u put 5s in a 5c case that what i want 2 know
Update (07/01/2016)
???????? Can any 1 help coz i want the fingerprint scanner botton on it but loking like a 5c with the colour
Es esta una buena pregunta?
I'm starting to think he doesn't mean an after market case, like otter box. I think he means the frame. As in he wants a 5c with a Touch ID button. It'll never work... I don't think....
Fue útil esta respuesta?
I'm afraid not. They have different dimensions. If the case is flexible it might work, but generally the answer will be no.
If your concern is about a thumbprint scanner, you'll need to find a case that doesn't cover it.
If you just want a colored case that doesn't cover the thumbprint scanner, you can definitely find that! You just likely won't be able to find a case designed for the 5c that fits the 5s.
Here's an image of the dimensions comparing the two (the iPhone light was the original name for the 5c before it was released:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
