replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
Es esta una buena pregunta?
thanks
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
Fue útil esta respuesta?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 140
4 comentarios
or another more powerful, as the model a1229
- de davidegatt
Why do you think the logic board is broken?
- de mayer
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
- de davidegatt
- de davidegatt
