The Samsung Galaxy S4 Active is a rugged version of the Galaxy S4. Currently, it is only on AT&T's 4G LTE network.
Preguntas 44 Ver todo
Can I use a different model to replace the LCD?
Okay, I have the Verizon version of S4 SCH-I545. The LCD needs to be replaced. I also have available a working LCD from the ATT I337 S4 which includes the frame. I read that they have different frames and home flex so you can't just use any version to replace LCD.Can I just switch the LCD to the Verizon model motherboard?.Do all the motherboards match up? Can I just transfer all the parts to the I337 LCD frame? Or is the home flex connection different on the verizon motherboard?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
It says that the S4 active is AT&T only... Is it unlocked?
por
Agregar un comentario
1 Respuesta
Solución Elegida
No. The Samsung Galaxy S4 screen is completely different from the Samsung Galaxy S4 active screen. Neither will work on the other.
Fue útil esta respuesta?
Calificación 2
Comentarios:
Are all the ATT S4's using an active screen? I don't know if mine is active.Anyway to check?
por
Añadir tu respuesta
xsilicon9 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 10
Todo El Tiempo: 439
