Charger piece broke off in DS
What can I do to fix it , I have a lot of DS games and don't want to get rid of them and the DS . Where can I get it fixed
Es esta una buena pregunta?
Remove the battery and get some fine point tweezers to see if you can remove the charger piece from the outside. If you're not able to remove it that way, then open up the bottom shell and try to push the piece out from inside the system. If you still cannot get the piece out then you'll need to desolder the charge port and put a new one back on. It's not a terrible soldering job and a new charge port is pretty cheap off eBay.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 208
