The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
Preguntas 173 Ver todo
'Black Screen of Death'? Need Help
So, my New 3DS XL (the model with amiibo support and the c-stick) suddenly stopped working. While trying to fix an issue with the 3D not working right, both screens went black. I could still hear the music and sounds playing on the main menu, but I can't select anything. The system also doesn't turn off right away when pressing the power button and it doesn't go to sleep when closed either. Everyone else I've asked thinks that I must've dropped it and knocked something loose, but after opening up the system and checking, I can't tell what's wrong. I've given up looking it up on the internet because all I get is how to fix a similar problem with the older models, and that doesn't help me in the slightest. I'm really frustrated right now and just want a straight answer. Can anyone tell me what's wrong? And how to fix it, because as a college student I really don't have the time or money to send it in for repairs.
As a side note, I bought this system over a year ago, so the warranty is expired. I'd rather not just buy a new one because I have no way of transferring my profile over to a new system. And this means I'll loose all $150+ worth of games, DLC, themes, and whatnot I've bought over 2 years of owning a 3DS, not to mention all the Pokemon I currently have stored in Pokemon Bank. So a new system is out of the question unless there's an alternate way for me to copy over/transfer my profile.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Okay, I'm guessing by now you've either pulled the battery to turn it off or it's completely shut down on it's own. In either case, when you try to turn the system back on, does it seem to stop mid boot with both LCDs apparently on but black and the power indicator blue with no other lights?
If you've answered yes, then it's probably a fault in the lower LCD. I've fixed three older XL models by replacing the lower LCD screen and can confirm they work and are fixed that way. So with that, I would invest the $10-20 on a new lower LCD off eBay to fix your problem. Make sure you also have a #00-000 phillips screw driver or get a LCD that comes with tools so you can open it up and replace the screen.
I hope this helps get you back on track to playing, good luck!
Also follow this guide to replace your lower LCD: Nintendo 3DS XL 2015 Motherboard Replacement. You won't need to remove everything they suggest here.
Fue útil esta respuesta?
Calificación 3
Comentarios:
I need easy ways to fix my 3ds black screen of death problem! I miss playing with my 3ds and I really want to play Pokémon Y! Tell me some tips an I will try them. The motherboard idea is the one I don't have everything that is needed. If these tips do not work out for me I will have to give it to someone to fix it... I wonder how long it will take and how it will go. I hope it goes very well! Thanks a lot ifixit.com for all the help ful tips you gave to many people! You're the best forum. At least i think this is a forum... You are very helpful people. Please help! No "black screens of death!!!!!!!!!!!!!!!! This is so unfortunate for me!!!!!!!!!!!!!! Please help!!!! Or maybe it is just my warranty for my 3ds... And I was thinking of switching SD Cards but then it will be unable to read the data......... Thanks guys, you are very helpful but for now I can just watch playthrough and try my hardest to fix my 3ds ba abuse of my unfortunate loss of my 3ds but fortunately, it can be brung back to life. Thanks!
por
The black screen of death has came!!! Both of my screens are black. Please help me fix it. I have tried everything!
How do you get it anyway? I just want a quick and easy way to fix it.
Calificación 0
Have you tried killing the battery and recharging it?
Calificación 0
I drops my Nintendo while charging for 2 times but then it still works.1 day later the screen turn dark but I can still a bit. the home screen work fine at that time.A few minute later the Nintendo screens turn black (both of them). but i think the waters go into the Nintendo a bit.
Calificación 0
Comentarios:
My 3DS has a fault where it would boot up as normal, but the screen would flash and a single POP noise can be heard. I believe it's a microtear in the speaker cable but I don't repair Nintendos for a living.
por
Añadir tu respuesta
Kate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 18
Últimos 7 Días: 47
Últimos 30 Días: 261
Todo El Tiempo: 8,933
