Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Modelo A1312 / Mediados de 2011 / Procesador Core i5 de 2.7 & 3.1 GHz o Core i7 de 3.4 GHz
Preguntas 585 Ver todo
Broken some pins on the logic board
hello guys
I swapped the GPU and added an SSD but i accidently damaged some contacts on the logic board these are forconnecting the display.
here some pictures:
http://imgur.com/a/d2gun
How should I proceed
thank you
Update (06/06/2016)
Thanks for the answers I got some knowledge in soldering I should be able to do the job if the bending doesnt help
Can anybody hit me up with a link where I can buy this part?
Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
2 Respuestas
Respuesta Más Útil
If they're just bent (I can't tell for sure because the picture is a bit blurry) I would recommend using something like a small flathead screwdriver and gently attempting to straighten them. If you get it close enough, the cable should mate to the connector without much issue. Those look like they're just contacts and not pins so they don't need to be perfectly straight. According to what I've read those pins are for display power so they're pretty important.
Fue útil esta respuesta?
Puntuación 3
You'll need to find someone to replace the connector for you. As they say plumbers can't do brain surgery, don't feel bad I'm a plumber too! ;-}
The only other option is to see if you can get a replacement logic board but that will be costly too.
Puntuación 0
Añadir tu respuesta
pulac77 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 162
