Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Lanzado en abril de 2010 / 2.4, procesadores Core i7 de 2.53 GHz o procesadores Core i7 de 2.66 GHz
Preguntas 632 Ver todo
MacBook Pro TrackPad Scrolling Problem (click are ok but not scroll)
Hello. I have a strange problem with my Macbook Pro A1286 Core i5 2.4 Ghz and Trackpad.
The trackpad "click function" is good, but there is no way to resolve the problem of no scrolling.
I have try also to change the trackpad with a new one and to change also the entire trackpad cable but I haven't resolve my problem.
Try also to Reset PRAM and SMC but without any result.
Try also to Remove the battery ... nothing ...
So I have start to check the Macbook Mainboard for try to find something that can be the cause to the problem.
All it seem to be ok, but there is a small point that I would understand that can be the cause of all.
I attach some photos...you can find a "small" component that it seem to have a small break ...
So the question is:- "can be this component the cause of all ?".
Or do you have any idea about the solution of the problem ?
Thanks in advance for your help guys.
Update (06/05/2016)
Other shots
other shots
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
From your images it looks like you do have a damaged chip which you've marked. Can you take a shot at a 45 degree angle looking at the break. That way we can see if the chip has failed or the case is just damaged.
What often happens here is a short will cause the chip to explode from the inside cracking the case.
Did you get your system wet?
- de
Thanks Dan .. I attach other shots ... (no the system not wet) .. I think that the small break was caused from a memory that was fallen up to the chip.
- de
Still hard to tell as the new pics are a bit out of focus.
- de
I attach you other shots Dan . Better than this is impossible due to the dimension of the chip.
- de
Wow! What a collection! I think the auto focus is getting in the way here. But I think you caught a good snap that shows the connection to the logic board has snapped on one of the legs. This also looks like a SMC capacitor. Hopefully our buddy @oldturkey03 can help us here.
- de
Mostrar 4 comentarios más
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
Respuesta Más Útil
You said click works, but can you also move the mouse pointer around with one finger? If so, test to see if other multitouch gestures work. If any of them work you can rule out the possibility of a hardware problem. There could also be an issue with Mac OS X settings that is causing multitouch not to work properly. If you have OS X install media (or the ability to create a bootable USB drive), boot the computer off of that and see if the gestures work in the OS X installer.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
thanks for your answer Chris ... no, I can not move the mouse pinter around with one finger ... sometimes the mouse pointer do a small movement, but only sometimes ... and no one multitouch gestures work. Like I told in my request only the left and right click are well.
- de
Añadir tu respuesta
Davide Ferrari estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,041
