2 receiver connecting problem
I have 2 receivers 100ft apart. I want to connect them. I tried to run 100ft of stereo wire then split both ends to rca but it didn't work. Help
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
@tripp723 connect two receivers (make and model?) how to accomplish what?
- de oldturkey03
I agree with @tripp723 why are you even trying to connect two receivers to one another? A receiver is used to connect Audio devices so that the sound can go to the speakers that are connected to the receiver. The only way i could image why you want to connect two receivers is to boost the already boosted audio from the first receiver. (I bless your ears because you are gonna need it.) Connect the Audio Output the the Aux input of the other receiver. "Keep in mind that you already have a boosted audio from the first receiver and you could be putting a over powered input to the second receiver which could very well blow up the amplifier of the second amplifier in the second receiver." (I personally do not recommend this but what do I know.)
- de Brian Reeder
