Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Preguntas 141 Ver todo
2DS Black Screen while power on
So a few days ago, I left my 2DS on the sleep mode for a while and I might or might not drop it accidentally. I don't remember and found out later that when i push the power button to turn it on, the blue led lights and the screen is black,
not black like it was turn off but black we definitely see that it is turn on but won't show anything. (backlight working probably?)
I tried to hold the power 10 seconds and wait but the only image i can see is when I push the power button when it's on and it asks you if you are sure if you want to turn it off. From there, and from there only, I can push the home button and it shows the white screen telling you you're going to the home screen. but it is stuck there and won't go to the actual home screen.
I want to know what exactly is the problem here and if you know how to fix it i would be grateful.
thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Mine is staying black period! I cant do anything at all! I cant take it apart because Im not techy. I will tell the story and tell me if you can fix it in any way! I got Kool-Aid inside of it! I can turn it on but it is black and it makes sounds like I am choosing a game! I need help D:
- Por
Unless there are other things not responding properly, it just sounds like the LCD screen needs to be replaced. This can be replaced fairly easily .
- Por
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
2 Respuestas
Respuesta Más Útil
I have a similar issue, where I turn on my 2DS and the screens turn on, but stay black. But your issue sounds like hardware failure, maybe the motherboard was damaged in the possible fall. You can get replacement motherboards for around $20 or more, and there are a great deal of tutorials online on how to replace them. Good luck to you!
Fue útil esta respuesta?
Puntuación 1
Comentarios:
Or you could remove the WiFi chip and put it back in
- Por
I had this the other day turns out when you accidently knock the ds when in sleep mode the sleep button dislodges from the switch just flip the button back and forth till it connects back with the switch might take a few speedy flips to jolt it back in.
Puntuación 1
Comentarios:
"I had this the other day turns out when you accidently knock the ds when in sleep mode the sleep button dislodges from the switch just flip the button back and forth till it connects back with the switch might take a few speedy flips to jolt it back in."
The issue you are describing sounds like a 2ds stuck in sleep mode, which is a bit different from what the poster described, as on sleep mode, the 2ds won't have the backlight on, nor will it show the home screen option.
- Por
thank you so much
- Por
Añadir tu respuesta
MaryEve Perreault estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 19
Ultimos 7 días: 129
Ultimos 30 días: 451
Todo El Tiempo: 13,150
