This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
Preguntas 26 Ver todo
Microphone only works in speaker phone mode
When I make calls or try to change my voicemail greeting, the microphone on my LG Tribute 2 does not pick up any voice input unless I'm using the speakerphone. I haven't had any problems using voice input for Google searches or Google Maps and since I can still use the speaker mode, I don't think it's a problem with the outside of the microphone needing to be cleaned (there's no dust or lint).
Any ideas? I've only had the phone for a month and haven't dropped/damaged it . . . yet.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
3 Respuestas
The mic down by your charge port is dead. There are two, unless I'm confusing myself again. The one that operates while using the speakerphone mode is up top near the earpiece. Unfortunately, I think everything is on one board in these phones, so this is not a part that can just be swapped out. I would go back to your service provider and explain what's going on. That there is no physical damage makes it probable that this is a manufacturer's defect.
Fue útil esta respuesta?
Calificación 0
I faced same problem.. I did clean mic.. I did reset factory setting and erased all data no use.. Beside blocking some applications may effect.. Finally I installed an app from store called (microphone guard) and its work 100%.. Just give a try
https://play.google.com/store/apps/detai...
Calificación 0
Comentarios:
I don't see how an app that mutes the mic should get a non-working mic to work.
por
Could be a firmware or software issue. The problem with mine is that the voice output is very muffled and there is nothing blocking both mics so hopefully they can update this to add a fix or improvement.
Calificación 0
Comentarios:
"POSTED: 06/09/2016 OPTIONS
It's work, you can give a try
por
Añadir tu respuesta
Becky estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 57
Últimos 30 Días: 256
Todo El Tiempo: 10,209
