The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
Preguntas 24 Ver todo
Why won't my speaker connect to my device?
The bluetooth on my device is on, but it is having trouble connecting to the speaker. What should I do to fix this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
6 Respuestas
Solución Elegida
Bose SoundLink Color Troubleshooting
Cannot pair speaker with Bluetooth® device
Try these steps to resolve your issue:
Make sure your speaker is discoverable. Press Bluetooth until the Bluetooth indicator slowly blinks blue
Make sure Bluetooth is turned ON or enabled on your device
Make sure you select “Bose Color SoundLink” in you device's pairing list and that the connection is confirmed by your device
Your Bluetooth device may be out of range. Try moving it closer to the speaker
If possible, turn off all other nearby Bluetooth devices or disable their Bluetooth functionality
Make sure your Bluetooth device supports the A2DP (stereo Bluetooth) profile
When connecting to a PC or Mac computer, make sure to select the Bose® SoundLink® Color speaker as the audio output device within the audio settings menu of the device. You may need to play an audio track to finalize the connection (see the device manufacturer for detailed instructions)
Try resetting your speaker. For more information, see Restoring your system's factory settings
Check for updated software for your Bluetooth device, or go to owners.Bose.com for updates to the Bose® SoundLink® Color speaker
This is from the official troubleshooting guide
Fue útil esta respuesta?
Calificación 3
Comentarios:
The numerical code I receive on my phone is correct but it won't pair with the Bose because it says the code is incorrect.
por
After connecting two speakers (bose soundlink revolve+ music was coming from 1 speaker other speaker?
por
Respuesta Más Útil
This worked for me....!To reset the Bose SoundLink Speaker:
On the speaker, press and hold the Mute button for 10-12 seconds or until the LED Indicators Flash
The speaker should now be powered off, now press the Power button to power the speaker back on.
Now, try connecting your Bluetooth device to the Bose SoundLink Wireless Speaker.
Calificación 7
Comentarios:
Thank you so much.
por
Thanks so much buddy!!!
por
Thanks, this worked for me.
por
Give the man a beer!
Thanks a lot.
por
Yes this did the trick , saved me a lot of time and aggro. Cheers DM UK
por
Everything I tried from online wasn't working for me to resolve the issue of Bluetooth connection.
Here is what worked for me.
1. Went to Control panel and uninstalled Realtek Audio Driver
2. Restarted my machine.
3. Windows asked me to restart again - I think this time it was to finish installing the newer version of the driver. Hence I see today's date after the restart.
4. Made sure the Aux Cable wasn't hooked up to my machine.
5. Turned on the Bose Speaker and pressed the Bluetooth button until the light started blinking
6. Went to Bluetooth & other devices and click on the + button to Add Bluetooth or other devices
7. This time it showed my Bose speaker on the Audio Section instead of other devices section.
And there it worked.
If it is still NOT working go to Sound setting from the control panel and make your Bose Speaker the default device by clicking on the <Set Default> button below.
Hope this works out for you and it did for me.
Calificación 1
I just had this same problem with my iPhone. The speaker said it was connected to my phone and my Bluetooth list said connected. The LED light on the speakers keep flashing and the music was still playing from my phone, so it obviously was not connected despite both devices saying it was. I went to my Bluetooth settings and clicked 'forget this device'. The Bose came up again under devices, so I clicked to connect and it fixed the problem. Working just like it should now.
Calificación 0
Comentarios:
I did all that but it didn't work. At a loss. It suddenly stopped working last night.
por
If someone else hooked up to your speaker and never unpaired befor you tried to pair then thats the problem. My girfriend and i had the same problem.
por
Tried all of the above to no avail. Any other suggestions?
Calificación 0
Comentarios:
I too used to have my iPhone connected, but it stopped recognizing so I "forgot it" and tried to connect again. Now my iPhone sees it but cannot pair to it. Ideas please
por
Same problem. wWorking solution please.
por
I have a Chromebook and i want to connect it to my samsung sound system(Samsung mx f 630) but it won't connect
Any help?
Calificación 0
Añadir tu respuesta
Brett Horstketter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 82
Últimos 7 Días: 666
Últimos 30 Días: 3,637
Todo El Tiempo: 76,515
