The Epson WorkForce 645 is an all-in-one office color inkjet printer.
Preguntas 27 Ver todo
Not printing red or blue ink
I think the printer ink channel/tube what ever it is call is clogged when I print I only get black and yellow is there away to clean the printer head. I have used the cleaning option on the printer as well as the head alinement option I have also replaced the ink cartridges but nothing has worked. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I have used this product before and it worked great for a customer with a Epson Workforce inject printer.
http://www.amazon.com/review/R2D2U3M1IJ6...
http://www.amazon.com/Cleaning-Kit-Epson...
jim
Fue útil esta respuesta?
Calificación 1
Epson Workforce 645 Ink Cartridge Replacement Tips
Step 1: Power on your Epson Workforce 645 printer.
Step 2: Wait for the LCD screen of the printer to inform you that an ink cartridge needs to be replaced.
  • If you want to replace an ink cartridge before its ink has been fully used up, press “Setup,” followed by “Maintenance,” then select “Ink Cartridge Replacement.”
Step 3: Press ”OK,” then select “Replace now.”
Step 4: Lift up the scanning unit of the printer.
Step 5: Open the cover of the ink cartridge compartment.
Step 6: Squeeze the tab located at the top of the ink cartridge, and lift the cartridge up and out of the printer.
Step 7: Dispose of the old ink cartridge immediately to prevent the ink from coming into contact with your skin, and with other working parts of the printer.
Step 8: Shake the new ink cartridge gently five times prior to removing the cartridge from its wrapper. Shaking the cartridge without packaging could result in an ink spill.
Step 9: Remove the ink cartridge carefully from its packaging without touching the green chip located on the cartridge.
Step 10: Remove the piece of yellow tape located at the bottom of the ink cartridge.
Step 11: Push the new ink cartridge firmly down into the holder until it clicks into place.
Step 12: Close and push down the cover of the ink compartment until it clicks into place.
Step 13: Lower the scanner unit into its original position.
  • Your printer will take up to three minutes to charge the ink, and will display a confirmation message on the console informing you that the printer is ready for use.
Calificación 0
Añadir tu respuesta
Lonnie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 40
Últimos 30 Días: 169
Todo El Tiempo: 2,270
