Saltar al contenido principal
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1158 Ver todo
No USB Connection after I broke little SMD element near connector #4!
I can neither charge the iPhone nor connect it to iTunes. Nothing happens when the phone is connected to a USB/charging cable. If the iPhone is off, connecting a cable turn it on.
It seems I broke a little SMD element near connector4 of the logic board when I disconnected this connector with a screwdriver!!!
Does anybody know what type of SMD element that is and where I can buy it? It is so little that I lost it on my table and never find that part again!
See picture:
Update
I am having this problem, but I just checked my board and that SMD looks perfectly intact. What else could be? The connector 4 is firmly attached as well...
Es esta una buena pregunta?
Puntuación 1
1 comentario
If you still have the mentioned SMD coil and your iPhone starts up when connected with usb charger it's another problem. Start you own question!
The coil filters the USB data lines. Maybe your line is broken on another point?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
I found an answer myself:
This element is coil!
Connect like this:
http://forum.gsmhosting.com/vbb/f631/iph...
Fue útil esta respuesta?
Puntuación 2
1 comentario:
It was the "NOISE FILTER COM MODE 90 OHM SMD" -> Digikey part number: P14216CT-ND. http://forum.gsmhosting.com/vbb/f631/iph... - Data Sheet here: http://industrial.panasonic.com/www-data... (Common mode Noise Filters, Noise reduction of high-speed data lines such as USB,
LVDS, and HDMI lines)
- de
Añadir tu respuesta
James Bond estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 13,030
