Saltar al contenido principal
Pregunta Cerrada
Can I upgrade 1600mhz ram in my Laptop instead of 1333mhz
I have a Lenovo G570 Laptop, I using 1333 MHz DDR3 RAM now I want upgrade my Ram so can I upgrade 1600mhz DDR3 ram Instead of 1333mhz ddr3 ram or can I use( 4*4) Ram one is 1333mhz DDR3 and one is 1600mhz ddr3 .
Should I use new (4*4) 1600mhz DDR3 Ram and it would be compatible for my Lenovog570.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Crucial website will have that information.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Pretty handy website. Never knew of it.
So this Laptop supports up to 1866MHz DDR3L-SODIMM RAM / memory.
- de
always check the manufacturers website to see if the ram is compatible with your laptop. other then that sometimes when you use ram that is faster than what it originally had, the new ram will not perform at optimal peak and will work at a slower rate. I hope this is helpful and you are able to upgrade your ram successfully
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,150
