Original screen worked but was broken, new screen backlight won't work
I have an HP Stream that had a broken screen but when I swapped the screen out for a working one, the backlight doesn't work. I don't think these laptops have a replaceable inverter so how do I get the backlight to work? I have tried the new screen on a two separate HP Stream that had lit but broken screens and the same thing happened to both so I don't think its the motherboard. I have also tried resetting the HP to factory settings to no avail. Anyone have any other ideas to try? Has anyone else had this same problem?
Es esta una buena pregunta?
3 comentarios
Hi, Does it have the same part number as the original one that you are replacing? I assume that it is the correct screen for the laptop?
You say that it is a working one but then you say it is a new screen. If it is a new screen have you actually seen it working?
Bit of work but did you try one of the other lit but broken screens in the first Stream, (if they are also the correct screen for the laptop)? If the backlight works (obviously not the screen) it proves the laptop OK and that your new screen might be the problem.
- de jayeff
Yes I did. I even put the original screen (the broken but lit one) that came with the Stream back in just to see if it would work and the backlight still didn't light.
- de Jason Kratochwill
there is a fuse on the mother board the goes out easily. there is a video on youtube that shows how to fix it.
https://www.youtube.com/watch?reload=9&v...
- de Steven Mestres-Junque
