El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3642 Ver todo
Ripped the home button cable, can I still fix it?
I took apart my phone and ripped the home button cable, but I didn't tear the cable, I detached it from the screen side. Now the home button does not work at all. I was wondering if there was an easy way to reattach it instead of having to buy a new part. I know the touch ID might not work, but I just want to regain the home button's abilities.
Just to be clear, the cable was not ripped in any way, as you can see by the pictures below it was separated near the home button.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
You're going to have to replace the home button. Fixing this is very tricky as it requires a some soldering skills I'm not sure if this is even possible with a soldering iron and a microscope. You might need one of those expensive flex repair machines.
por
Agregar un comentario
1 Respuesta
Solución Elegida
I agree With Ben on this one you need to replace the home button which up till a few weeks ago was a death sentence for your phone but you can now replace the home button and not end up with error 53. you will lose the touch id function of the home button when you replace it but there is a fix for the errror that will come up when you update the phone after replacing the home button
https://support.apple.com/en-ca/HT205628
a help for replacing the home button
iPhone 5s Home Button Replacement
replacement part
iPhone 5s Home Button Assembly
Hope this helps
Imagen iPhone 5s Home Button Assembly
Producto
$34.99
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Jack estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 15
Últimos 7 Días: 115
Últimos 30 Días: 410
Todo El Tiempo: 9,805
