Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Preguntas 371 Ver todo
My systems system is slow, takes time to booth, and hangs indefinitely
Macbok Air 13" Mid 2012 Repair
Whenever I put my system on it takes time to boot, usually shows the beach ball repeatedly for long when in the middle of operations. I don't know what might be the cause, I need help.
Es esta una buena pregunta?
Puntuación 1
3 comentarios
How much free space do you have on your drive?
- de
Total space is 121.33GB, 83.11GB Used, 37.88GB Free
- de
That's getting tight! The smaller SSD drives need at least 1/3 of the space empty for swap & virtual RAM (depending on the app).
- de
Agregar un comentario
2 Respuestas
Solución Elegida
With SSD's free space is also needed so the drive evenly wears.
At this point I would recommend you create a bootable USB thumb drive so you can boot up under it to run Disk Utility - Disk First Aid. Let's see what it tells us. If you still have Mavericks run repair permissions and then repair disk.
Fue útil esta respuesta?
Puntuación 2
In addition to running to using the Disk Utility (which you can also run in recovery mode - hold down Command + R when powering on and wait until you see the Apple logo before releasing the keys)
I wouls also suggest doing a PRAM reset as the the System Manager table may be a little corrupted. To do this, press the Option-Command-P-R and Power button and hold until you hear the boot fanfare 3 time and then release all the keys. Your MBA will rediscover the hardware and create a new boot table.
Puntuación 0
Añadir tu respuesta
Joseph estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 159
