Saltar al contenido principal
Una videoconsola producida por Sony Computer Entertainment, también conocida como PS4. Anunciada el 20 de febrero de 2013 y lanzada el 15 de noviembre de 2013.
Preguntas 1700 Ver todo
Ps4 turns on using controller only, internal Peripherals won't work.
Hi All, i'm new and i am from Italy. I'm trying to fix my old ps4, a first gen model (chassis A). So, after thermal repaste my ps4 won't start up using capacitive lid sensor (power button) but sometimes i'm able to start it up using the controller ps button. Warranty is obviously voided and I don't want to pay 150$ to replace it because I've already bought the new 1Tb ps4 model. The strange thing is that every internal pheripheal (including capacitive buttons and optical drive) doesn't work. i think it's not a power supply issue... Software Maybe? it seems like the main motherboard runs on her own without communicating with others Hardware pieces! Do you think a Motherboard Reballing Could Help? Thank you!
Es esta una buena pregunta?
Puntuación 0
1 comentario
Either you damaged some components / cables or they are all not plugged in properly. It's also possible that the connector plugs for the ribbon cables are damaged.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
The first thing I would do is remove the plastic covers and see if the console will power up using just the copper pad on the motherboard. I would also check the function of the disc drive using the copper pad on the disc drive board.
If all works well then it means that the metal pieces on the case is not touching the copper pad on the motherboard when the plastic case is installed.
I hope this helps.
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
How would you power up using just the copper pad?
- de
Just plug it in and touch the copper pad with your finger.
- de
The copper pads don't respond
Puntuación 0
1 comentario:
Follow my recommendation below
- de
Did you (donnie96) find the solution by any chance?
Update (01/06/2019)
This cable is not plugged in all the way, check both ends of it. Let me know if you got it working, I had the same problem and just fixed it, thank god for blue prints!
Puntuación 0
1 comentario:
By the way it's under the power supply unit AKA: PSU
- de
Añadir tu respuesta
donnie96 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 2,331
