Volume button flex cable replacement mute switch loose
I just replaced the volume button flex cable in a 6 (actually a 6 Plus). The mute switch is loose and doesn't work properly. It seems like it needs pressure on the top edge of the inner switch to function properly. When I press my finger on the top edge of the switch it clicks and functions normally. Without pressure, the switch doesn't click or work properly. I've transferred everything from the old cable. The back plate is installed properly. I can't figure out how to keep it in place to work properly. I've replaced tons of volume and power button flex cables in other models. It took me a while to figure out some things especially with the iphone 5 power/volume flex but I'm very experienced with these types of cable replacements (5 years of pro repair experience) and I'm stumped with this one. Please help! Thanks!
Es esta una buena pregunta?
This may be a stupid question but have you checked the buttons to see if anything has peeled off on it or the screws are in the correct spots? Maybe you need to loosen it or tighten it more?
- de Ben
I also have encountered this problem, I have done many replacements for earlier iPhone models but for some reason after replacement it either isn't a solid click motion or doesn't work all together. The only way I have gotten around this is purchase a new housing and remove the volume/mute button component as a whole unit and insert into original housing. It means I am purchasing a housing that will most likely not get used but it is the only way I have found to be as good as an original replacement. If anyone has anything to add that has worked for them I would love to hear it!
- de Andres
