Saltar al contenido principal
This is the Insignia Flex 8, a versatile tablet created by Tianshi Digi-Lando that can connect to the internet, take photographs, and use apps.
Preguntas 12 Ver todo
Why can't I connect to the WiFi with my tablet?
My tablet is turned on and is functioning, but it can't connect to the WiFi. Is there a way I can fix it to make it connect to the WiFi?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 7
7 comentarios
Hi,
Is the tablet's WiFi turned on? Can you 'see' the network name (or any other networks for that matter) that you want to connect to? What happens when you try to connect - are you required to connect using a password? What is actually happening when you try to connect?
- de
Hi, when i turned on the WIFI i can't see the network name.and it says no internet
- de
When I go to my network to see my wifi it just shows airplane mode and it's turned off somewhere I lost part of my programming and I can't figure out how to get it back
- de
My insignia tablet is not opening. It is stuck with the logo on the front screen. How can I get to the page to reset it
- de
This is not an answer. If you want to ask this you should create a new post describing your issue.
- de
Mostrar 2 comentarios más
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This is a common issue. First, make sure you are in range of an existing Wi-Fi network and double check if your device's Wi-Fi is turned on and your settings are correct. If that doesn't work, find out if your network is WPA or WEP. Use this troubleshooting page to help you out: Insignia Flex 8 NS-P16AT08 Troubleshooting
Fue útil esta respuesta?
Puntuación 1
I reset the network settings and it works but the real test is if it actually works elsewhere.
Puntuación 1
Añadir tu respuesta
James Stryd estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 18,604
