Saltar al contenido principal
Versión simplificada y de menor costo del chipset XFX 680.
Preguntas 3 Ver todo
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
Es esta una buena pregunta?
Puntuación 1
1 comentario
did I mention this is for an XFX board?
read: running Windows 7.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
- de
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
- de
Añadir tu respuesta
tabormeister estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 4,330
