Disassembly Headphone Sennheiser RS 120
Good morning. Please, How to disassembly the Headphone of Sennheiser RS 120 ? (Not the Trasmitter). Thanks.
Es esta una buena pregunta?
I repaired some similar Sennheiser headphones recently. If you press the ear pads down towards the centre you will see a series of around a dozen plastic tabs which retain a piece of plastic to which the ear pads are attached. Prise this plastic out from the tabs with a small screwdriver or prying tool and the ear pads will come off.
You will then see an oval of foam surrounding the driver. Under this are 4 screws that you can locate by feel. Remove them and the driver comes out. Replacing it, the fork has to be in the correct position before it will sit flush.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 796
