Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1530 Ver todo
Bottom portion of touchscreen barely works
So i replaced my screen last night and everything works perfectly. Even the touchscreen works fine except for the bottom portion. Its the keyboard area that doesnt work properly. It will work but most the time when i click on a letter lets say i click on the letter "d". Most the time it wont even click on the letter d it will click on any of the surrounding letters and it will type atleast 5 of them. It will let me type fine for about 5 seconds and then it will either hit another button or it wont at all i will have to hit it about 3 or 4 times before it registers. Is my screen bad?
Also I did update and restore my phone with no results.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
I just purchased the entire LCD, screen digitizer, camera kit from iFixit.com and everything is fine on it accept similar to the above person the very bottom of the screen is hard to get a response from. I have to click several times on something before it finally recognizes the touch. Did I get a defective unit or is this just a poor quality OEM replacement?
- de
Agregar un comentario
SALTEA LA ACTUALIZACIÓN
Ahorra reparando con un kit todo en uno.
Compra Kits de Reparación
1 Respuesta
Respuesta Más Útil
Sounds like a bad digitizer Shea! It's possible the connection is bad though - try cleaning the pins conservatively with rubbing alcohol and reattaching the cable. Because these connections are wider than their predecessors, I connect one side at a time and then press the middle down last to hear the faint snap. If you're confident in the connection, I'd order a replacement!
Fue útil esta respuesta?
Puntuación 1
Comentarios:
I will check the connectors here soon and if thats still the problem I will order a replacement. Thank you
- de
Añadir tu respuesta
Shea Garrigan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 63
