How do I prevent my adapter from overheating?
I am trying to figure out what can be done to prevent the adapter from over heating.
Es esta una buena pregunta?
I had this sort of problem in the Philippines for a TV adapter. Due to the extreme heat of the country and the lack of airflow the ac adapter was overheating and the TV would turn off after a certain amount of time. So I had on of those Gel Cooling Pads for a laptop which I was not using. Mine looked like this.
http://www.amazon.com/Heat-Absorbing-Lap...
Anyway I wrapped it around the power adapter brick and rubber-banded it on.
OF course you might use something else but remember you are dealing with power so be careful.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 518
I was in this problem before
But i stooped use adapter
no i use SD card only
and everything right
- de Nasser Gad
