Saltar al contenido principal
Cámara Samsung WB2200F con zoom de 60x y doble empuñadura lanzada en 2014.
Preguntas 6 Ver todo
Why can't I remove the cover of the camera?
After taking out all of the screws from the body of the camera, the outer shell will not come off.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Usually the body shell has small plastic hooks inside that keep it together even when the screws are removed. Also, note that sometimes screws are hidden under stickers: make sure you remove these too.
Once the screws are all out, you need a prying tool to gently pry the shell apart along the seams without breaking the hooks.
Pay attention, the shell may have flat cables attached to it that must be carefully disconnected before the shell can be detached completely.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rachelle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 97
