Saltar al contenido principal
Un netbook Gateway lanzado en marzo de 2009, identificado por el número de modelo LT2014u.
Preguntas 2 Ver todo
Pregunta Cerrada
What do I do if my audio is distorted or absent?
Can modify the audio if needed?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Check to see that the volume, located in the bottom right corner of the screen, is turned on loud enough. Check to see that the volume output on your computer is on loud enough. This may include the device’s speakers or headphones, if you have any plugged in. If so, check to see that the speakers are plugged in all the way. If you are running a program, check to see that the volume in the program is turned on loud enough. If none of these solve your problem, you may have a faulty driver. Note: Any of these solutions could result in your volume suddenly being very loud.
Fue útil esta respuesta?
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 30
