Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 4015 Ver todo
Tried everything with the screen, doesnt work. Need HELP!Nthngs Broken
Hi, So some things i would like to tell -
  1. - Yeh, i do take my phone in shower, ive been doing it for years and before u conclude its water damage,== PLEASE! read on.. ==
  2. - My phone didnt stop working after immediately being exposed to water, In fact the touch stopped working for every few seconds, 6 HRS. after being exposed to water in my shower.
  3. -I didnt know what to make out of it, so i ignored it for the time being.... But it got worse
  4. - One thing i d like to point out is, it was fine before i plugged it to my car's AUX port.
  5. (Look i dont know wether its relevant or just a co-incidence but thought, i should point that out, Ofcourse i dont see any reason it would stop working because of that as i ve done it a hundred times before)
(call me paranoid bt wtever)
Ok now for the actual problem
My touchscreen used to respond occassionally.
Say, i left it over night untouched and still, i would be able to use it for 15 mins before the touch becomes unresponsive again.
== Problem-
-Touchscreen still responds but very occassianally.
-There are faint but noticable vertical black lines. ==
What i did-
-Obviously i googled "iphone 5s Touchscreen vertical lines fix" and followed the instructions in the video.
My cables were clean and had no sign of dust
Unfortunately it didnt work
Things i would like to point out-
- No! i didnt drop my phone, the touch suddenly became unresponsive while i was using it. I was in a function so I didnt think much of it.
- I dont think its water damage, cuz if it was, i would ve seen some definite corrosion
All the tapes indicating water damage are WHITE
Plus, Wouldnt other things go wrong it there was water damage??
I mean, everything but the touchscreen works perfectly, yes, perfectly FINE!
What are my options-
- So either m thinking of selling this phone for some money and buy a new one.
- Or i wanna know if buying another screen with digitizer assembly would fix the issue
PLEASE RESPOND TO THIS QUICK AND TO THE BEST OF UR ABILITIES ,
Thanks :D
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Essential Electronics Toolkit
Pequeño juego de herramientas. Grandes posibilidades.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
2 Respuestas
Not necessarily. Water damage can strike in several different ways, and there are some cases where the water-evident stripes won't trip, even if there is water damage. In environments like a shower, high humidity can cause shorts and permanent damage, even if the strips don't trip. You may want to start with a display assembly replacement (the display glass/digitizer and LCD are one fused unit). If that doesn't fix the problem, then the entire logic board will be the next option.
This is a VERY difficult repair if not experienced, and if you're not extremely careful, it's easy to lose many of the very small screws that hold the device together.
Fue útil esta respuesta?
Puntuación 0
From what I understand it seems that you have a faulty screen. I would try another screen assembly before selling it, it's difficult that something has been damaged by water if you have white tapes on the board, they are very sensitive.
Puntuación 0
Añadir tu respuesta
vishishtmakkar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 81
