Saltar al contenido principal
Clean light still blinking 7 times after I installed a new element
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Not sure what to do now?
Any help will be appreciated.
Thanks
Chris
Es esta una buena pregunta?
Puntuación 0
Comentarios:
I have the same issue - once it was replaced, it is heating the water but after the rinse the light will flash again 7 times. I have reset but still have the. BLinking light
- de
Agregar un comentario
1 Respuesta
Solución Elegida
The flashing "clean light" indicates, a water temperature, heating problem.
It could be due to, a bad heater element, thermostat, or a control board.
Most of the time, it's due to a low water temperature.
You need to make sure, the water temperature, in the bottom of the tub, on the first fill of a wash cycle, is at least 120 to 130 dgrs. F. (you should be able to run the hot water faucet at the kitchen sink, and get somewhere in that range, before you start the dishwasher).
Read more: http://forum.appliancepartspros.com/dish...
http://www.appliancepartspros.com
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
chrisandhelene estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 36
Ultimos 30 días: 123
Todo El Tiempo: 8,140
