Galaxy tablet lite variation released January 2014. The Samsung Galaxy Tab 3 Lite is lightweight and an easy-to-use tablet.
Preguntas 21 Ver todo
I can't charge my tablet
My tablet has stopped charging even though I plug it in. I have tried a different charger, and different wall outlets, still the same issue.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If you have tried a different charger, then there is a good chance that it is either battery issue or a problem with the micro USB port. I would suggest starting with the easiest option, replacing the battery. Refer to the battery replacement guide. Once the battery is replaced, plug in the charger and charge it.
If the tablet still will not charge with a new battery, then you will need to replace the micro USB port. Refer to the Micro USB Replacement Guide.
For more information check out the Troubleshooting Page.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Kevin Hicks estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 14
Todo El Tiempo: 674
