Saltar al contenido principal
Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4901 Ver todo
iPhone only charges without original cable!
I got quite an interesting iPhone which charges only with an aftermarket cable and doesn't recognize original cable lol ! Also it takes 7-8 hours to charge and 3 hours to discharge completely when left idle with network and wifi.
I have replaced complete lightning part and battery as well so that's definitely not the issue with iPhone. Here are my possible assumptions/solutions but need your suggestions.
1) There is issue with power IC and should try replacing it.
2) Mother board is damaged due to using it with aftermarket cable maybe for overnight charges.
What you guys say on it ?
AND yes i have tried restoring it and it's out of warranty.
Contestar esta pregunta I have this problem too
Puntuación 0
Comentarios:
Same EXACT problem. Let me know if you fixed it? Thanks!
by
Añadir un comentario
Kits de Reparación de Android
Estás a un kit de tu nueva pantalla o batería.
Comprar Ahora
Comprar Ahora
2 Respuestas
Most Helpful Answer
I will say number 2
U2 chip
¿Ha sido útil esta respuesta?
Puntuación 2
Comentarios:
Ah so I should try U2 chip first ?
by
This is just guessing I presume is the chip but until you don't change it and see if make different you won't know. Good luck
by
Did you try with more than 1 original Apple cable? if not try another.
Try clean the port with rubbing alcohol. I noticed you said you changed the battery and it still only have 3 hours of battery ? that sounds weird to me, more weird than the charging problem.
To understand the lightning cable real fast I need to explain something.
The tip of the lightning cable actually has a small chip inside of it that talks to the charging port and asks permission to charge or not to charge. So I dont think it is the cables fault. I have used many off brand cables on my iPhone without any issue. So I think it has something to do with the component.
Take it apart and put it back together
Puntuación 0
Comentarios:
Thanks for your reply. Yes I tried like 10 cables and i said above that i changed the port with another working one so need to clean it as it's working with other phones. Yes I changed the battery and it lasts for 3 hours only due to fault somewhere in board.
by
Add your answer
indergillnz will be eternally grateful.
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
Global: 1,120
