Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2128 Ver todo
Lcd replacement gone wrong
Changed the lcd on a 6s and when I went to go connect the digitizer and other connectors smoke came up is this a new thing on the 6s where the connectors can touch the wrong receivers and when I turned it on it was very dim
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Did you turn off the phone and unplug the battery before plugging in the screen? I really don't know why some people in repair shops don't do that.
- Por
Agregar un comentario
2 Respuestas
It sounds like something has shorted on the board. Did you disconnect and remove the battery? Not doing so means there is still power going through the board (even if the phone is powered off)
Only other thing I can think of is a static discharge has damaged the screen connectors
Fue útil esta respuesta?
Puntuación 0
back light fuse is gone . It`s more common than you would think when you preform repair on the phone without disconnecting battery. Solution is to find some one who could replace that fuse.
Puntuación 0
Añadir tu respuesta
Albert Einstein estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 155
