Saltar al contenido principal
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
Preguntas 248 Ver todo
Why does JVC Receiver have to warm up before I get sound?
Suddenly I stopped getting sound from my receiver. I noticed if I turned it on and let it warm up for several minutes, and then turned it off and back on, the sound would kick in.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios
Hi, What is the model number of the receiver?
- de
It's a RX-8010VBK
- de
My JVC does the same thing.
I had a problem with one of the relays so i replaced it. I got sound the 1st time, but then after that, speakers stopped working again. Now it needs to warm up for a few minutes before it works. Any ideas?
- de
My 8030V started doing this about a month ago
- de
Hi @felderga
You have just posted a question as a "Comment" on to a 6 year old "Question".
You will get better results if you post a new question from this page:
https://www.ifixit.com/Answers
clicking on "Ask a Question" box up on top right of page.
Also don't forget to include more details such as make, model, symptoms, anything you have tried, etc.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@dlongtin sounds like there is a possibility of a cold solder at the amplifier section. Try to run the self diagnose function and see what it shows. You most likely will have to open your amp to check things out. So you do want to make sure that you have the right tools i.e. proper screw drivers and multimeter.
Let us know what the tests tell you.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Thank you. Not sure if I have the tools to do this.
- de
Añadir tu respuesta
dlongti1 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 452
