Get to know Transmisson Fluid
How much Transmission does the 1990 Toyota 4runner hold after changing the filter and gasket.
Es esta una buena pregunta?
forrestshook this should help:
REPLACE AUTOMATIC TRANSMISSION FLUID
(a) Remove the drain plug(s) and drain the fluid.
(b) Reinstall the drain plug(s) securely.
(c) With the engine OFF, add new fluid through the dipstick tube.
Fluid:
ATF DEXRON)II
Drain and refill capacity:
2WD
A340E
1.8 liters (1.7 US qts. 1.4 Imp. qts)
4WD
A340H
4.5 liters (4.8 US qts. 4.0 Imp. qts)
A340F
2.0 liters (2.1 US qts, 1.8 Imp. qts)
(d) Start the engine and shift the selector into all positions from ”P” through ”L” and then shift into ”P”.
(e) A340 H :
Shift the transfer lever position: H2–H4–L4 and L4 –H4–H2.
(f) With the engine idling, check the fluid level.
Add fluid up to the cool level on the dipstick.
(g) Check that the fluid level is in the ”HOT” range at the normal operating temperature (70 – 80* C or 158 – 176° F) and add as necessary.
NOTICE: Do not overfill.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 48
Todo El Tiempo: 13,635
