Why can't I make or receive calls
My phone won't receive or make calls and I have no data. It only works on wifi but the calls just don't work.
Es esta una buena pregunta?
. You're able to access this troubleshooting guide from another device or computer
2. You're in an Optus 2G / 3G / 4G Plus coverage area. You can confirm here.
3. You've successfully made calls at your present location before (unless roaming)
4. You're not using a Home Zone device
5. You've checked for a known problem with the Optus Network in your area. You can check here.
WHILST TESTING, PLEASE...
- Switch off Bluetooth and/or Wi-Fi on your device
- Monitor your device's status bar
- Use your device's native calling/phone application (Avoid using third party calling apps whilst testing)
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 903
2 comentarios
Need a bit more info, is the sim card detected?
- de Wadski
cant` call out,can`t reseive,doesn`t pickup wifi
- de Terry Fenton
