Tablet has a pink screen, how can I fix this problem?
Tablet has a pink bach ground screen, I have already reset to factory settings and it didn't fix the problem. What can I do to fix this problem?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
What can I do to fix my color screen tab
por
Agregar un comentario
4 Respuestas
Solución Elegida
This is generally a failing display or digitizer, Replace it.
Here's how to do it: https://www.youtube.com/watch?v=7N9--kUh...
Fue útil esta respuesta?
Calificación 4
Sometimes the graphics cable gets dislodged
Prise open the back
Black flat cable to the right
Check line on the cable lines up with board line
A wiggle and a push helps the cable in
Put some tape across connector to prevent further dislodgement
Hope this helps
Paul
Calificación 1
I removed the connector, cleaned it off , and put it on again. And now are all the colors there again!
Thank's a lot!
Best regards Erland
Calificación 0
My whole screen is pink and that only thing I see on my tablet what causes this
Calificación 0
Comentarios:
Tablet has been dropped or not correctly reassembled after battery install
por
Añadir tu respuesta
barryh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 11
Últimos 7 Días: 87
Últimos 30 Días: 320
Todo El Tiempo: 5,638
