Saltar al contenido principal
Pregunta Cerrada
stuck on searching wont initialize
Hi, phone stuck on searching, won't activate via wifi or itunes. Itunes sees it, attempts to start the activation process then stops and the icon greys out. All this after screen replacement. I have bricked it...I know I know...never erase a phone showing Searching...Sadly I didn't see this website before doing the deed... Now I have a useless paperweight...or do I??? Only screen I can get into is wifi settings. Have updated ios and itunes. Any suggestions would be helpful. Thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
So it's stuck on the activation screen it seems. Have you check for the imei number if it's still there by clicking in the blue i, at the bottom right hand corner of the lock screen that shows the 'hello' in multiple languages?
If it isn't there then you have a logic board component issue where the imei is missing.
Have you tried restoring the iPhone 5? You will lose all data when restoring your iPhone.
How to put your iPhone or iPad into recovery mode:
1. Turn Off your iPhone, iPod touch, or iPad if it isn't off already.
2. Press and hold down the On/Off button on the right side (iPhone 6 or later) or top (all other iPhones, iPods, and iPads) for 3 seconds.
3. Swipe the slide to power off confirmation slider to the right.
4. Press and hold down the Home button on your iPhone, iPod touch, or iPhone.
5. Plug your iPhone, iPod touch, or iPad into your Mac or Windows PC and make sure iTunes is running.
6. Release the Home button when you see the Connect to iTunes screen.
7. At this point iTunes should display an alert saying it's detected an iPhone, iPod touch, or iPad in recovery mode, and will let you restore your device.
Fue útil esta respuesta?
Puntuación 0
You have a big problem. I wish I knew how the fix the no service problem but I don't. You should bring your phone to a professional repair business to get that fixed. Only then you will be able to activate it.
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 298
