keyboard and trackpad is not working, MacBook won't start
Macbook Air 13" a1466
Hey there,
the trackpad and the keyboard of a friends macbook air isn't working anymore. her machine just went black and nothing worked anymore, not even the power button.
when i disconnect all the connections from the keyboard, trackpad and battery the macbook starts when i attach the power supply to it.
now my question: are they any parts beside the keyboard and the trackpad that could cause this problem? there do i start to replace stuff? any ideas?
thanks for your help!
Update (09.03.2016)
sure, sorry for that one.
the Part Number is MD760D/A.
Update (15.04.2016)
Ok, here we go again. So i replaced the keyboard and both, trackpad and keyboard was working again so i put the battery back in and tryed to start the computer but nothing happend. So i tryed again to start the computer without the battery connected but it wont start. So i disconnected the trackpad/keyboard cable again and plugged the meg safe back in. The computer starts. I shut it down again, connected the trackpad/keyboard cable again but doesn't connectet the battery. The macbook air startet and it was possible to use both without any problems but when i connect the battery again it won't start, even with the battery disconnected again it wont start, i have to remove the trackpad and keyboard cable again to get the maschine starting.
So i tryed the smc reset while the keyboard and the trackpad was working, but nothing changed.
Any ideas what could cause this problem? Is it possible that the trackpad is causing these problems? Or the battery? I really could use some advice here.
Thank you guys!
Update (04/19/2016)
no idea? anybody? thanks again for your help. i will try to get a new trackpad and will see how it works.
Es esta una buena pregunta?
5 comentarios
There are eight A1466 models running from 2012 to 2015. Can you be more specific?
- de mayer
MD760D/A.
MacBook Air "Core i5" 1.3 13" (Mid-2013) 1.3 GHz Core i5 (I5-4250U)
Intro. June 10, 2013 Disc. April 29, 2014
Order MD760LL/A* Model A1466 (EMC 2632)
Family Mid-2013 ID MacBookAir6,2
RAM 4 GB VRAM 1.5 GB
Storage 128 GB, 256 GB SSD Optical None*
Complete MacBook Air "Core i5" 1.3 13" (Mid-2013) Specs
MacBook Air "Core i5" 1.4 13" (Early 2014) 1.4 GHz Core i5 (I5-4260U)
Intro. April 29, 2014 Disc. March 9, 2015
Order MD760LL/B* Model A1466 (EMC 2632)
Family Early 2014 ID MacBookAir6,2
- de mayer
Did she spill anything on the keyboard? Was it dropped? Any thing else you can tell us about its history.
- de mayer
She told me that the maschine just dindt start after she puts it to sleep and after that there was no functinality at all. No liquid damage and not dropped.
- de laurids wiemer
After you connected the battery your new trackpad and mouse stopped working, sounds like the battery fried it. so I wouldn't use that battery again. Also If you get a new battery and another new keyboard and track pad. Please test the battery first before connecting the keyboard mouse. Reason behind this is if the battery charges and works then the chances the keyboard and track pad will probably work but if the battery won't work, even a new one then you saved not frying another keyboard/trackpad.
- de Brian Reeder
