Released 2015 Model Number: POLSP01W
Preguntas 34 Ver todo
Why won't my Polaroid SNAP turn on?
After multiple attempts of trying to power on my Polaroid SNAP, it still won't turn on. What gives??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
I have the same issue. Did you figure out the problem?
por
My snap touch after update firmware with app Snap touch do not turn on...
por
Agregar un comentario
5 Respuestas
Respuesta Más Útil
If you did left it out without using it, It is probably just on sleep mode. Try turning it on and back off for it to work. It that does not work maybe it just died and you will need to charge the battery.
Fue útil esta respuesta?
Calificación 1
Comentarios:
Also, please refer to the "Camera Will Not Turn On" section of the Polaroid SNAP Troubleshooting page if you are having any more difficulty.
por
i tried doing both but it just doesnt work or charge at all
por
My polaroid snap was not turning on either. I figured out that the problem was that a little plastic piece under the pop up visor was stuck. Touch it with your finger, try to release it and the camera will turn on.
Good luck!
Calificación 1
Comentarios:
what did you mean by plastic piece? where exactely is the on switch on that visor?
por
My Polaroid camera is on with all the lights flashing but the power pop up is not on ??? How do i get it to work. I don’t know what to do at this point... i think it doesn’t work because all the lights are on and the camera is shut off
Calificación 0
I just opened my snap touch from the box and it wont turn on. I tried charging it but while its charging its making this beeping noise and still the screen isn't turning on. I tried resetting it and its still not turning on????
Calificación 0
I just restarted it by inserting an earring in the hole in the bottom
Calificación 0
Añadir tu respuesta
Aaron Hall estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 16
Últimos 7 Días: 139
Últimos 30 Días: 589
Todo El Tiempo: 10,039
