Saltar al contenido principal
Cámara de 20,1 megapíxeles de Sony diseñada para capturar imágenes fijas y grabar videos. Número de modelo: DSC-W800.
Preguntas 11 Ver todo
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
يرجى توضيح أكثر هذا قليلا
- de
@tcampo what happens when you do replace the batteries? does it then turn on?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Thomas Campo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,353
