Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
iPhone 5S Charging Problem
Hello,
I replaced the battery from an Iphone 5S with an new one from ebay, afterwards the loudspeaker was dead. Replaced loudspeaker and lightning port unit with a new one. Speaker is working again, but battery won't charge anymore. Little lightning symbol in the upper corner indicates battery is charging, but even after hours on cable, battery is losing power instead of charging. Installed the old dock connector unit, Iphone is charging again, but loudspeaker is dead.
Any help would be appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
You have a faulty dock flex, which is common with ebay parts. You will have to get another. i suggest getting one from ifixit :)
Fue útil esta respuesta?
Puntuación 1
Hello,
I have the same problem except I bought the battery here.
Puntuación 0
common on the Five S if you have a known working dock, battery and good charger is what is called the tristar IC chip -this regulates charging-
Microsoldering.com, Ipad rehab are 2 places to start for this repair.
Puntuación 0
Añadir tu respuesta
matt estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 271
