Saltar al contenido principal
Repair guides and support for televisions manufactured by Panasonic.
Preguntas 20 Ver todo
TV screen won't turn on. Standby light solid red.
My Panasonic Viera plasma TV won't turn on. It won't respond to the tv remote. If you press the power button on the side of the tv the red standby light comes on solid but the screen doesn't turn on. No sound comes out either. After the red standby light comes on the buttons on the side of the tv don't do anything, including the power button.
Es esta una buena pregunta?
Puntuación 21
12 comentarios
Now I just noticed that the solid light started blinking. It blinks 14 times and then stops for a second then blinks 14 times again.
- de
I have a problem where the tv turns off it self after 1 minute when turned on and the red light blinks ? In that case what is to be done any solution please
- de
My Cornea TV wont even turn on.If I turn it on the blue light flicks on and just for a while it changes to red meaning its switched off again.
please in need of urgent assistance.
- de
My tv is onida co. , When won't turn on , tv not displaying picture & come to red light of standby mode , plz give the solution
- de
The tv brand is nippon made in china 21 inches, the problems is the power is on then the led red color changes to color yellow then the monitor is black, how to solve?
- de
Mostrar 7 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
Here's a video on fixing the 14 blink code on the Panasonic plasma 50 inch TV:
https://www.youtube.com/watch?v=iHBIiRxh...
Fue útil esta respuesta?
Puntuación 13
5 comentarios:
Great that works!
- de
Fantastic I'm back in business cheers from clip
- de
Don’t understand what do I press
- de
Thank you so much Bugsy13! I thought I was going to have to get a new tv but your solution worked!
- de
Telefunken tledd-32 does not power on what can it be
- de
Respuesta Más Útil
Turn tv off at the tv. Now keep your remote stand bye button held down. Whilst held down, press tv button on. Green light should come on. From bugsy13
Puntuación 53
56 comentarios:
I tried everything to solve our similar problem with our Panasonic Vieira TV and this is the one thing that finally worked. Thank you so much!
- de
I'm a manager at a retirement apartment block. A 94 year old resident told me her tv wouldn't come on. I went through all of the fault finding in the book, but got no answer. I put the problem into google and your response came up. I went back to the tv and lo and behold it worked! Thanks so much for posting this solution.
- de
Panasonic TX-P42U30B. Red light on and flashes with commands from remote but does not come on. This reset worked a treat. Now changes to flashing green and then starts. Many thanks, Have since found out
that set had suffered a power cut, so this could have caused the need for a reset
- de
OMG it worked! A million thanks!
- de
thx so much, this really helped
- de
Mostrar 51 comentarios más
Turn tv off at the tv. Now keep your remote stand bye button held down. Whilst held down, press tv button on. Green light should come on. I found this answer on the ‘Net’ and it worked a treat for my mother’s TV.
Puntuación 2
Hold the button down on the side of the TV and keep it held down. At the same time press the ‘on button’ on your remote control until the green light appears. DO NOT take your finger off the TV button until about 10 seconds. Release the TV button and hope for the best! It worked for us . Good luck.
Puntuación 1
1 comentario:
Many thanks,worked a treat
- de
Añadir tu respuesta
Randy Weaver estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 46
Ultimos 30 días: 232
Todo El Tiempo: 187,421
