Saltar al contenido principal
La Canon EOS 300D es una cámara réflex digital de objetivo único de nivel básico de 6.3 megapíxeles.
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
4 Respuestas
Solución Elegida
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
Fue útil esta respuesta?
Puntuación 0
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Puntuación 0
This can also be caused by a defective/broken CF door switch
Puntuación 0
Could it be for any other situations, as I have done all checks and keep the problem.
Puntuación 0
Añadir tu respuesta
Rob estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,734
