Repair guides and support for phones manufactured by BLU Products.
Preguntas 1687 Ver todo
mobile network not available
worked this moring when calling to doctor but not working now at 3pm still can't get work.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
My phone would not turn on
por
My network not working how to fix
por
How do I get pass my google count to open it? My blue sell phone?
por
Mere moile ka network cale ghe Hi
por
Agregar un comentario
6 Respuestas
Respuesta Más Útil
Some Simple Solutions:
Solution#1
  • Switch off your smartphone.
  • Remove bettery and also your Sim Card and wait for some time.
  • Reinsert battery and sim card and turn your phone on.
Solution#2
Set your mobile network to automatic .
Solution#3
Update your phone software.
These solution will probably fix error while searching for networks.
Hope it helps.
Fue útil esta respuesta?
Calificación 1
I have the same problem with the network
Calificación 1
restart phone,
if not get network check airplane mode is ON, if it ON then turn off it
still not have network, check imei by dialing *#06#
if it error rewrite imei code
if it not error
need to check network connection part
Calificación 0
How do connect to the internet
Calificación 0
Comentarios:
Hi @slock001 ,
Check that the Data Connection setting is enabled. Not quite sure of your phone but go to Home > Settings > Wireless and Networks > more > Mobile Networks > Data Connection.
This setting is useful if you want to control your cell data usage. If you turn it off your apps cannot connect to the internet 'in the background' without you being aware of it. Turn it on when you want to use it. You also need it on for MMS messages (texts with pictures)
Then just use the browser app on your phone.
Alternatively turn on your WiFi setting in the phone and connect via an appropriate network
por
My data is not responding, I cannot browse, look Facebook. Pls to me how to set it up on blu phone vivo 5 mini
Calificación 0
Comentarios:
I want to use mobile data not WiFi. Pls explain me the settings
por
Which sim do you have. go to setting and mobile network and try manual search for mobile network. and look for your network and register it. Or go to setting sim management and then disable sim and then again reactive it. or lastly remove sim and insert again.
Calificación 0
Añadir tu respuesta
pam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 34
Últimos 7 Días: 280
Últimos 30 Días: 1,257
Todo El Tiempo: 21,879
